2 Diagrams
Documents
Models
601752060
Background
The Bosch Angle Grinder 1752G is a durable, multipurpose tool designed for grinding, sanding, brushing, sharpening, and deburring. Manufactured by Bosch, a trusted name in power tools, this corded electric grinder is made of metal for long-term reliability.
Equipped with a 15-amp motor, it operates at 120 volts and delivers a maximum rotational speed of 6000 RPM. Its 5/8-inch-11 spindle thread allows compatibility with popular accessories, while a spindle lock ensures swift wheel changes. For enhanced control and versatility, it features a 3-position auxiliary handle and a lock-on/lock-off switch.
The Bosch 1752G has been discontinued by the manufacturer, but its solid design and performance make it a notable tool in the category. It weighs 12.75 pounds and has package dimensions of 22.5 x 7.6 x 4.4 inches. Sold as a bare tool without attachments, it carries the part number 1752G.
Technical Specifications
  • Model Number: 1752G
  • Product Type: Angle Grinder
  • Brand: BOSCH
  • Material: Metal
  • Power Source: Corded Electric
  • Voltage: 120 Volts
  • Maximum Rotational Speed: 6000 RPM
  • Manufacturer: Bosch
  • Part Number: 1752G
  • Item Weight: 12.75 pounds
  • Package Dimensions: 22.5 x 7.6 x 4.4 inches
  • Item model number: 1752G
  • Is Discontinued By Manufacturer: Yes
  • Item Package Quantity: 1
  • Special Features: heavy-duty
  • Included Components: bare-tool; attachments
  • Motor: 750 watt, 120V AC, 11 amp
  • No-load speed: 11,000 rpm
  • Disc diameter: 4.5 inches
  • Spindle thread: 5/8"-11
  • Weight: 5 lbs
Warranty
The Bosch Angle Grinder 1752G comes with a standard warranty that lasts for one year from the date of purchase. This warranty covers defects in materials and workmanship. It is important to note that the warranty only applies to the original purchaser and is not transferable. The warranty does not cover normal wear and tear that occurs during use of the product. To claim the warranty, it is usually required to provide proof of purchase and to contact the manufacturer or authorized service provider. Always refer to the warranty information provided with your product for specific instructions.
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 4
Past 7 Days: 8
Past 30 Days: 74
All Time: 938
