Up to 20% off select tools
Guides
Documents
Tools
These are some common tools used to work on this device. You might not need every tool for every procedure.
Background and Identification
The Bionaire Mini Tower fan is a compact fan created for tight spaces. Its quiet operation makes it suitable for an office or workspace. The fan has an oscillating feature that allows movement to cool down an entire room and users can vary the amount of air circulation with the fan’s two speed settings. Portable with its convenient carrying handle, the Bionaire Mini Tower can be taken anywhere.
The most common issue users face is difficulty turning the fan on. If your fan has trouble starting, try moving it to another outlet in a different room. Sometimes, there could be a problem with the wall outlet. If the outlet works, most likely the fuse within the plug has blown out.
Features:
  • Slim, space-saving design and quiet operation are ideal for personal space cooling.
  • Two speed settings.
  • Oscillation for wide area coverage.
  • Top mounted push-button control interface.
  • Metallic accented housing.
  • Integrated carry handle for easy portability.
  • 3 year limited warranty
Technical Specifications
  • UPC Retail: 048894031106
  • UPC Carton: 00000000000000
  • Color(s): Black/Silver
  • Depth: 6 4/5"
  • Fan Type: Tower
  • Global Product Type: Fans-Countertop/Table Tower
  • Height: 13 1/4"
  • Speeds: 2
  • Width: 7"
  • SKU: BNRBT014AU
  • Inventory Unit Code: EA
  • UPC: 048894031106
  • Manufactured In: China
  • Manufacturer: Bionaire
  • Manuf Part #: BNRBT014AU
  • Model: BT014AU
  • Weight: 3.5 lbs
  • Warranty: Manufacturer's limited three-year warranty.
  • UNSPSC: 40101604
Additional Information
Bionaire Fan FAQs
Bionaire Mini Tower Fan Walmart
Bionaire Mini Tower Fan Staples
Reviews Best Buy
Bionaire BT440RC and BT410RC Remote Control Tower Fan Instruction Leaflet
Bionaire BT014/BT015 Mini Tower Fan Instruction Leaflet
Author
with
Kyle Wiens
24,774 Reputation
5 Guides authored
iFixit Member of iFixit
Staff
119 Members
72,966 Guides authored
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 43
All Time: 7,363
