Up to 20% off select tools
Background and Identification
The BenQ TH530 Projector is a small, compact single-chip digital light processing (DLP) projector that is designed to extract images from Full HD content. This model was released in May 2016 with a one-year warranty.
The projector can show video on screens up to 300 inches diagonal on any wall. The projector features full 1080p (1920 by 1080 pixels) resolution and a 10,000:1 high-contrast ratio. The BenQ TH530 Projector’s bulb produces 3,200 ANSI lumens. It also features full 3D compatibility. The BenQ TH530 Projector includes a 270-Watt ultra-high pressure (UHP) bulb (lamp model 5J.JFH05.001) that has a life of up to 4,000 hours or up to 6,500 hours on Eco mode. The model’s included lens features 1.1-times manual zoom and manual focus. The projector does not include optical lenses.
The BenQ TH530 Projector has a throw distance of 3.5 feet to 32.0 feet with an image size of 30.0 feet to 300.0 feet. The projector’s connection panel includes a Mini Jack audio in and audio out port, a composite RCA port, an HDMI port, an RS232 Db-9pin port, an S-video port, a USB port, and two VGA in Dsub-15pin ports.
The BenQ TH530 Projector includes the name “BenQ” on the front of the device next to the projection lens. Other identifying information may be found on the top surface of the projector either printed on the body or on a sticker.
Technical Specifications
Brightness: 3,200 ANSI Lumens
Resolution: 1920x1080
Aspect Ratio: 16:9 (HD)
Contrast: 10,000:1 (full on/off)
Display Type: DLP x 1
Color Wheel: 6 segments
Color Processing: 10-bit
Input Lag: 33ms (min)
Video Modes: 720p, 1080i, 1080p/60, 576i, 576p, 480p, 480i
Data Modes: MAX 1920x1200
3D Modes: Full HD 3D
Lamp Type: 270W UHP bulb
Lamp Life: 4,000 hours  / 6,500 hours (Eco)
Lamp Model: 5J.JFH05.001  Buy Replacement Lamp
Included Lens: 1.1x manual zoom, manual focus
Optional Lenses: No
Lens Shift: No
Throw Distance: 3.5' - 32.0'  Calculate Throw Distance
Image Size: 30.00" - 300.00"
Throw Ratio: 1.47:1 - 1.62:1 (D:W)
Projector Placement: For a  "diagonal screen, place the projector lens between 10'-8" and 11'-9" from the screen.
Digital Keystone: Vertical only
Projector Size: 6.50" x 16.90" x 12.60" (HxWxD)
Weight: 4.3 lbs
Audible Noise: 33 dB  / 28 dB (Eco)
Internal Speakers: 2.0 Watts Mono
Power: 270 Watts 100V - 240V
Connection Panel:
  • Audio In: Mini Jack
  • Audio Out: Mini Jack
  • Composite: RCA
  • HDMI (MHL)
  • RS232: DB-9pin
  • S-Video
  • USB
  • VGA In: Dsub-15pin x 2
Features: Full HD 3D
Additional Information
Author
with
Docolin Dan
16 Reputation
0 Guides authored
Past 24 Hours: 0
Past 7 Days: 13
Past 30 Days: 63
All Time: 2,477
