Up to 20% off select tools
Potential Student Project
This page has been tagged for revision by students in our education program.
Student In Progress
This wiki is being worked on by hardworking students.
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Background
The Beko company started in 1995 in Sütlüce, Istanbul. The company released its first washing machine in 1959; however, it didn’t start producing its first dryers until 2005. The Beko DCU 6130 series, the dryer this page focuses on, launched in 2010. The condenser sensor tumbler dryers have an energy rating of 'B', which helps contribute to low energy consumption. The condenser allows for easier loading and unloading of larger laundry items such as bed sheets or comforters. The company designed the Tumbler dryers so that when the machine detects the level of dryness required for the load, it will stop automatically once that level is reached.
For the dryer's condenser system technology, any hot or humid air that flows into the condenser is cooled using cold air from the room; as the air cools, moisture condenses into water, and that condensed water is pumped into an internal water tank. In order to ensure that laundry isn't damaged, towards the end of a cycle, the dryer starts a cooling phase so no heat is applied during this stage. This ensures that the laundry is not left at a temperature that could cause some kind of damage to the clothes.
Additional Programs and Features
The dryer also has many programs and features to help care for the clothes. The Reverse Drum Action allows the dryer to rotate in both directions, reducing creasing of clothing. When you need to dry thicker fabric, like jeans, it has a jean program. It has a child safety feature that allows parents to lock the door to keep kids from attempting to open it or in case any accidents occur. Users can also schedule for a more convenient time when electricity rates are lower thanks to the time delay feature.
Identification
The Beko DCU 6130S is a silver dryer with a large round front-loading door, although other model numbers come in different colors. It is a front-loading, freestanding condenser tumble dryer with buttons, dials, and a display located on the top portion of the dryer's front. The bottom of the front contains both the kick plate and the kick plate opening tab. You can find the rating plate behind the loading door.
Technical Specifications
  1. Height (adjustable): 84.6 cm
  2. Width: 59.5 cm
  3. Depth: 53 cm
  4. Capacity (max.): 6 kg
  5. Weight (net): 36 kg
  6. Voltage: See type label
  7. Rated power input: See type label
  8. Model code: See type label
(The type label is located behind the loading door)
Additional Information
  1. Beko DCU 6130 Series Product Brochure (2012).
  2. Tumble Dryer
  3. Beko DCU6130 tumble dryer Freestanding Front-load
  4. Manual
Author
with
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 1
Past 7 Days: 12
Past 30 Days: 109
All Time: 368
