Up to 20% off select tools
Ask a Question
There are no questions. Be the first to ask a question!
Background Infromation
Introduced October 9, 2025, the P2S is the direct successor to the BambuLabs P1S. This new iteration in the P Series of 3D printers features a 5-inch touchscreen, quick-swap nozzle, and improved airflow control for different printing scenarios, and chamber temp control.
Technical Specifications
General Information
  • Printer Type: Fused Deposition Modeling
  • Build Volume:
    • 256 mm
    • 256 mm
    • 256 mm
  • Cassis Material: Plastic and Steel
  • Outer Frame: Plastic and Glass
Physical Dimensions
  • Phyical Dimensions:
    • Length: 392 mm
    • Width: 406 mm
    • Height: 478 mm
  • Net Weight: 14.9 kg
Toolhead
  • Extruder Gear Material: Hardened Steel
  • Nozel Material: Hardened Steel
  • Max Nozzle Temp: 300 °C
  • Included Nozzle Diameter: 0.4 mm
  • Supported Nozzel Diameters:
    • 0.2 mm
    • 0.4 mm
    • 0.6 mm
    • 0.8 mm
  • Filament Cutter: Built-in
  • Filament Diameter: 1.75 mm
  • Extruder Motor: Bambu lab High-percision Permanent Magnet Synchronous Motor
Build Plate
  • Build Plate Material: Flexible Steel Plate
  • Included Build Plate Type: Textured PEI Plate
  • Supported Build Plate Types:
    • Textured PEI Plate
    • Smooth PEI Plate
    • Cool Plate SuperTack
  • Max Heatbed Temp: 110 °C
Speed
  • Max Speed of Toolhead: 600 mm/s
  • Max Acceleration of Toolhead: 20.000 mm/s2
  • Max Flow for Hotend: 40 mm3/s (250 mm round model with one outer wall; Bambu Lab ABS @ 280 ℃)
Air Filtration
  • Filter Type: Activated Carbon
  • VOC Filtration Support: Yes
  • Particulate Matter Filtration Support: Yes
Cooling
  • Part Cooling Fan: Closed Loop Control
  • Cooling Fan for Hotend: Closed Loop Control
  • Auxillary Part Cooling Fan: Closed Loop Control
Supported Filaments
  • PLA
  • PETG
  • ABS
  • ASA
  • TPU
  • PA
  • PC
  • PVA
  • PLA-CF
  • PETG-CF
  • ABS-GF
  • ASA-CF
  • PA6-CF
  • PA6-GF
  • PAHT-CF
  • PPA-CF
  • PET-CF
Sensors
  • Camera: Built in Camera
    • Resolution: 1920 x 1080
    • FPS: 30 fps
  • Door Sensor Support: Yes
  • Filament Run Out Sensor: Yes
  • Filament Tangle Sensor: Yes
  • Filament Odometry Support: Yes w/ AMS
  • Power Loss Recovery: Yes
Electrical Requirements
  • Voltage: 100-120 VAC / 200-240 VAC, 50/60 Hz
  • Max Power: 1200 W @ 220 V / 1000 W @ 110 V
  • PLA Steady-State Power: 200 W @ 220 V / 200 W @ 110 V (PLA Printing)
Operating Environment
  • Operating Temp: 10 °C - 30 °C
Electronics
  • Touchscreen: 5" 854 x 480 Touchscreen
  • Storage: Built-in 8 gb EMMC & USB 2.0 Port
  • Control Interfaces:
    • Touchscreen
    • Mobile App
    • PC App
  • Motion Controller: Dual-core Cortex-M4 & Single-core Cortex-M7
  • Application Processor: Quad-core 1.5 GHz ARM A7
  • Neural Processing Unit: 2 TOPS
Software
  • First Party Slicers: Bambu Studio
  • Third-Party Support: Supports any third-party slicers that exports standard G-Code, but some advanced features might not be supported.
    • Super Slicer
    • PrusaSlicer
    • Cura
  • Supported Operating Systems:
    • MacOS
    • Windows
    • Linux (Ubuntu & Fedora)
Communication
Network Control
  • Ethernet: N/A
  • Wireless Network: Dual-band Wi-Fi
  • Network Kill Switch: N/A
Wi-Fi
  • Operating Frequencies:
    • 2412 MHz - 2472 MHz, 5150 MHz - 5850 MHz (FCC/CE)
    • 2400 MHz - 2483 MHz, 5150 MHz - 5850 MHz (SRRC)
  • Wi-Fi Transmitter Power (EIRP):
    • 2.4 GHz: <23 dBm (FCC); <29 dBm (CE/SRRC/MIC)
    • 5 GHz Band1/2: <23 dBm (FCC/CE/SRRC/MIC)
    • 5 GHz Band3: <30 dBm (CE); <24 dBm (FCC)
    • 5 GHz Band4: <23 dBm (FCC/SRRC); <14 dBm (CE)
  • Wi-Fi Protocol: IEEE 802.11 a/b/g/n
Additional Information
Author
with
Jacob Mehnert
50,876 Reputation
52 Guides authored
iFanatics Member of iFanatics
Community
71 Members
1,152 Guides authored
Past 24 Hours: 6
Past 7 Days: 50
Past 30 Days: 228
All Time: 278
