Up to 20% off select tools
Ask a Question
There are no questions. Be the first to ask a question!
Background
The Astro A50 X is a wireless gaming headset and base station from Logitech G. Logitech announced it on December 5, 2023.
The base station connects to Xbox Series X|S, PlayStation 5, and PC or Mac. The headset's Playsync button switches between connected systems. The base station also serves as a charging dock. The headset uses 40 mm Pro-G Graphene drivers and has a flip-to-mute boom microphone.
At its December 2023 announcement, the headset and base station were offered for preorder in the US for $379.99 USD.
Identification
The headset is identified by model number A00186 on the left earcup. The base station is identified separately by model number A00187 on its underside. Check these labels rather than relying on the A50 name alone.
The HDMI base station has two HDMI inputs and one HDMI output. Color options include Black and White.
Technical Specifications
Headset:
  • Weight: 363 g
  • Drivers: 40 mm Pro-G Graphene
  • Headphone frequency response: 20 Hz to 20 kHz
  • Microphone: Flip-to-mute omnidirectional boom; 60 Hz to 20 kHz; up to 16-bit/48 kHz sampling
  • Wireless audio: Lightspeed, up to 24-bit/48 kHz
  • Wireless range: Up to 12 m
Power:
  • Rated battery life: Up to 24 hours at 78 dB
  • Charging: Base-station dock or USB-C; the headset's USB-C port is for charging only
  • Full-charge time: Approximately three hours
Base Station:
  • Connections: Two HDMI 2.1 inputs, one HDMI 2.1 output, and three USB-C inputs
  • Bluetooth: 5.0
  • Power adapter output: 5.15 V / 2 A (10.3 W)
Dimensions and Weight:
  • Headset dimensions (H × W × D): 91.5 × 185.8 × 184.9 mm
  • Base dimensions (H × W × D): 40 × 123.4 × 147.7 mm
  • Base weight: 320 g
Additional Information
Author
with
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 5
Past 7 Days: 32
Past 30 Days: 98
All Time: 146
