Up to 20% off select tools
Ask a Question
There are no questions. Be the first to ask a question!
Background
The Astro A50 Gen 5 is a wireless gaming headset and charging base designed to switch audio between three connected gaming systems. The base connects to consoles and computers through USB-C, and the headset's Playsync control changes the active system. It uses Pro-G Graphene audio drivers and a 48 kHz boom microphone.
Identification
The fifth-generation A50 is supplied with a Playsync Audio base that connects three gaming systems through USB-C. Confirm the generation and base-station connections when comparing it with older A50 models or the A50 X; the shared A50 name does not establish repair compatibility.
Technical Specifications
Audio:
  • Drivers: 40 mm Pro-G Graphene
  • Microphone: Omnidirectional; 60 Hz to 20 kHz; up to 16-bit/48 kHz sampling
  • Headphone frequency response: 20 Hz to 20 kHz
Connections:
  • Wireless: Lightspeed
  • System inputs: USB-C connections to the base
  • Switching: Three systems through Playsync Audio
  • Base USB-C ports: Three device inputs and one power input
  • Base power adapter output: 5 V DC / 2 A
  • Base Bluetooth: 5.0 + LE
Dimensions and Weight:
  • Headset dimensions (H × W × D): 91.5 × 185.8 × 184.9 mm
  • Headset weight: 375 g
  • Base dimensions (H × W × D): 40 × 123.4 × 147.7 mm
  • Base weight: 305 g
Power:
  • Battery: Rechargeable lithium
  • Rated battery life: Up to 24 hours at 78 dB; varies with use
  • Charging: Base dock or USB-C; headset USB-C is charging-only
  • Full-charge time: Approximately three hours
Additional Information
Evan Gattuso
25,935 Reputation
7 Guides authored
iFixit Member of iFixit
Staff
119 Members
72,966 Guides authored
Past 24 Hours: 1
Past 7 Days: 19
Past 30 Days: 26
All Time: 26
