Popular Forum Questions
Ask a QuestionThere are no questions. Be the first to ask a question!
Background
The Astro A20 X is a wireless gaming headset with a Playsync Audio base that switches between two connected systems. It has a suspension headband, memory foam ear cushions, a boom microphone, and eight-zone Lightsync RGB lighting. Game and voice-chat levels can be adjusted through its MixAmp controls.
Identification
The A20 X pairs a suspension-headband headset with a two-system Playsync Audio base. Its boom microphone has an LED mute indicator, and the headset includes customizable RGB lighting. Confirm the A20 X product name when comparing it with other Astro A20 generations.
Technical Specifications
Audio:
- Drivers: 40 mm Pro-G
- Microphone: Boom microphone; 6 mm omnidirectional capsule; 70 Hz to 20 kHz response; 48 kHz sampling
- Headphone frequency response: 20 Hz to 20 kHz
- Headphone sensitivity: 107 dB ±3 dB
Connections and Controls:
- System switching: Two systems through Playsync Audio
- Connections: Lightspeed, Bluetooth, and USB-C
- Lighting: Eight-zone Lightsync RGB
- Bluetooth: 5.3 LE
- Wireless range: Up to 30 m
Dimensions and Weight:
- Headset dimensions (H × W × D): 194 × 190 × 83 mm
- Headset weight: 290 g
- Playsync base dimensions (H × W × D): 15.7 × 75.2 × 36.8 mm
- Playsync base weight: 48 g
Power:
- Battery: Rechargeable lithium polymer, 1500 mAh
- Rated battery life: 40 hours with lighting on or 90 hours with lighting off, at 78 dB SPL
- Full-charge time: Approximately 4 hours 45 minutes
- Charging input: USB-C, 5 V DC / 500 mA
