Opening for Repair
7 Answers 33 Score |
Time Capsule is overheating w/yellow flashing light |
8 Answers 9 Score |
Detailed Removal 2TB HD Plus Install 4TB HD + Formating |
12 Answers 13 Score |
How do I Upgrade the new AirPort A1470 to SSD? |
8 Answers 17 Score |
Replacement HDD larger than 2 TB? |
Documents
Upgrades
You can cost-effectively upgrade a number of components in the Time Capsule.
- Hard Drive: 1 TB, 2 TB or 3 TB SATA hard drives came standard with the Time Capsule. You can easily upgrade your Time Capsule hard drive following these simple steps.
- Power Supply: You can replace and or repair the power supply or remove the current power supply by adding a stand-alone power supply.
Model Names and Numbers
- Time Capsule 802.11n (1st Generation) (early 2008)
- MB276LL/A - 500GB
- MB277LL/A 1TB
- Time Capsulle 802.11n (2nd Generation) (early 2009)
- MB764LL/A - 500GB
- MB765LL/A - 1TB
- MB996LL/A - 2TB
- Time Capsule 802.11n (3rd Generation) (mid-2009)
- MC343LL/A - 1TB
- MC344LL/A - 2TB
- Time Capsule 802.11n (4th Generation ) (mid-2011)
- MD032LL/A - 2TB
- MD033LL/A - 3TB
- AirPort Time Capsule 802.11ac (mid-2013)
- ME177LL/A - 2TB
- ME182LL/A - 3TB
Background and Identification
The AirPort Time Capsule (also called the Apple Time Capsule or Time Capsule) is a wireless router produced by Apple, Inc as an AirPort product. The Time Capsule features network-attached storage (NAS) and a residential gateway router. Time Capsules are similar to the AirPort Extreme with an internal hard drive, though Apple markets it as a ‘Backup Appliance’ designed to work together with the Time Machine backup software utility that was first introduced in Mac OS X 10.5.
The Time Capsule was released in February 2008 and has been upgraded several times to match the upgrades in the Extreme series routers. All Time Capsule models include three Gigabit Ethernet ports and one USB port. The USB port can be used to connect external devices to be shared over the network such as printers or external hard drives. In 2018, Apple’s entire AirPort line was discontinued without replacement.
Depending on the AirPort model, the device’s serial number is located either on the bottom or side of the device. Users can also open the AirPort Utility in their computer’s Utilities folder, or by searching for it with the Spotlight feature. After opening the Utilities folder, select your AirPort product or base station and look for the serial number in the Summary tab.
Additional Information
Time Capsule: Guía de configuración
Apple AirPort Time Capsule Setup Guide
Computers & Accessories — Mac Product Catalog
