Up to 20% off select tools
Guides
Tools
These are some common tools used to work on this device. You might not need every tool for every procedure.
News
Apple Pencil Teardown
Background and Identification
The Apple Pencil is a stylus meant for use with the iPad Pro to enable precision markup and drawing. It has a 240 Hz refresh rate and highly precise pressure sensitivity. Identifying the Apple Pencil is simple—it is a simple white cylinder with no buttons. At 17.5 cm, it is longer than most styluses, and it's metal bezel is marked "Pencil." Additionally, the Lightning connector is labeled with the model number: A1603.
Technical Specifications
Input Sensitivity
  • iPad Pro scans Pencil input at 240 Hz
Power:
  • Built-in lithium-ion battery rated for 0.392 Wh and 86 mAh at 3.82 V
  • Delivers up to 12 hours of use on one charge
  • 15 seconds of charge yields 30 minutes of battery life
Connectivity
  • Lightning connector for charging and pairing with iPad Pro
  • Bluetooth 4.1
Dimensions
  • Size: 8.9 mm (D) x 175 mm (L)
  • Mass: 20g
Additional Information
Author
with
Evan Noronha
230,357 Reputation
166 Guides authored
Past 24 Hours: 55
Past 7 Days: 293
Past 30 Days: 1,202
All Time: 138,098
