Up to 20% off select tools
Guides
Documents
Tools
These are some common tools used to work on this device. You might not need every tool for every procedure.
Background and Identification
The LED Cinema Display is a monitor designed by Apple. The 24-inch version (here’s a link to that page) was released in 2008 but was soon replaced by the 27-inch model in July 2010. The 27” LED Cinema Display (model number A1316) features a glossy 2650x1440 pixel screen with a density of 109 pixels per inch. It has a built-in iSight camera above the screen, a microphone, and a stereo speaker system.
The body of the display is held up by a curved aluminum stand. The sides and back of the device are also made of aluminum, but the front side is made from a pane of glass covering the screen. On the back there are three USB 2.0 ports for peripherals like a mouse, keyboard, or flash drive. The back of the device also has an AC power cable and a combination cable that splits off at the end to a MagSafe charging cable, a Mini DisplayPort cable, and a USB 2.0 cable. While this display was designed to be used with a MacBook laptop—the MagSafe cable can charge any MacBook of the era—the screen can be driven by any computer with a Mini DisplayPort output or with a Mini DisplayPort adapter. The USB ports on the back will only work if the USB cable is connected to the computer as well.
You can identify the LED Cinema Display by looking for the serial number printed on the bottom of the stand. Enter those digits into Apple’s check warranty page to find the exact model of your display.
Technical Specifications
Display
  • 27 inches (68.6 cm) on the diagonal
  • 2560x1440 pixels
  • IPS panel
  • 109 ppi
  • Glossy
Connections
  • Three USB 2.0 ports
  • Cable with three breakout connectors:
    • MagSafe charger
    • Mini DisplayPort
    • USB 2.0 connector
Power
  • Up to 250 W (when charging a MacBook Pro)
  • AC power cord
Additional Information
Apple Cinema Display on Wikipedia
LED Cinema Display 27" specifications on EveryMac
LED Cinema Display review on CNET
LED Cinema Display review on AnandTech
Apple LED Cinema Display Manual
Author
with
jyavenard
73 Reputation
0 Guides authored
Past 24 Hours: 8
Past 7 Days: 79
Past 30 Days: 343
All Time: 81,895
