Up to 20% off select tools
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Background Information
Introduced in late 1983, the ImageWriter is a serial-based dot matrix printer made by Apple Computer. The printer's hardware featured similar hardware as the 9-pin dot matrix printer from C. Itoh Electronics (model C. Itoh 8510) with significant changes to the printers ROM and pinout.
While this printer was primarily intended to be used with the Apple II, the printer works across Apple's entire computer product line. The ImageWriter could produce images along with tex, up to a resolution of 144 DPI and of speed of 120 characters per second.
The ImageWriter could also support Microsoft Windows-based PC's by using the included C. Itoh 8510 compatible driver.
Tech Specs
Overview
  • Cost: $675 USD (Equivalent to $2011.43 in 2023)
  • Introduces: December of 1983
  • Discontinued: December of 1985
  • Type: Dot Matrix
  • Color: No
Logic Board
  • Processor: None
  • PD Language: QuickDraw
Ports
  • Ports: Serial
Power
  • Max Watts: 180
  • Amps: 1.5
  • BTU per Hr: 615.6
  • Voltage: 120
  • Frequency Range: 60 Hz
Memory
  • ROM Size: 32 KB
  • RAM Slots: 1
Engine
  • Pages per Min: 1-2
  • Max DPI: 144
  • Characters per Second(CPS): 120
Physical
  • Weight: 26.4 lbs
  • Height: 5.6"
  • Width: 22"
  • Depth: 11.8"
Additional Information
Author
with
Jacob Mehnert
50,876 Reputation
52 Guides authored
iFanatics Member of iFanatics
Community
71 Members
1,152 Guides authored
Past 24 Hours: 3
Past 7 Days: 18
Past 30 Days: 45
All Time: 1,458
