Up to 20% off select tools
4 Diagrams
Ask a Question
There are no questions. Be the first to ask a question!
Models
HDSB68LS/HDLS68
Background and Identification
Anderson trailers models HDSB68LS and HDLS68 are 5-foot by 8-foot solid wall trailers. A trailer is an unpowered vehicle that is designed to carry something and is towed by a powered vehicle. These models are manufactured by Anderson Trailer, which is one of the largest trailer, truck body, and equipment manufacturers in the South Eastern United States.
The HDSB68LS and HDLS68 models include a four-way flat style plug and a 2-inch adjustable coupler. The high-side trailer is designed to provide more security when transporting top-heavy and tall items. The trailer’s axle is rated for a 3,500-pound load but the manufacturer recommends not loading the trailer to over 2990 pounds.
The HDSB68LS and HDLS68 trailer models feature an 11-gauge floor with a diamond plate pattern that is designed to provide increased friction and prevent items from sliding while the trailer is in motion. The trailers include a three-way split ramp gate that acts as a barrier when closed and as a ramp when open. The trailer features heavy-duty tubular steel construction that is powder-coated a bright orange color. It has an open-sided design that includes tubular railings to more easily secure loads and an A-frame tongue for towing. These models also include a spare tire located at the front of the trailer above the A-frame.
Technical Specifications
  • GVWR: 2990 Lbs.
  • Coupler: 2" Adjustable Coupler
  • Axle: (1) 3500 Lb. Drop Axle
  • Floor: 11 Ga. Diamond Plate
  • Gate: 48" Hydraulic Assist
  • Jack: 5K Swivel Top Wind
  • Paint: Durable Powder Coat Finish
  • Frame: Tube Construction
  • Lights: DOT Compliant L.E.D.
  • Plug: 4-Way Flat Style
Additional Information
Author
with
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 11
Past 7 Days: 101
Past 30 Days: 523
All Time: 30,745
