1 Diagram
Popular Forum Questions
Ask a QuestionThere are no questions. Be the first to ask a question!
Documents
Models
APC4016
Background
The All-Power American APC416 is a portable electric air compressor designed for home, garage, and workshop use. The compressor uses an electric motor to power an air pump that compresses air and stores it in a 6-gallon tank for use with pneumatic tools or inflation equipment. According to the owner's manual, the compressor consists primarily of an electrical motor, pressure switch, and a storage tank.
The APC4016 operates on a standard 110 household electric outlet. The pressure switch automatically starts and stops the compressor when air pressure drops below or rises above the set limit. The tank stores the compressed air until it is needed.
Source: All-Power America. (n.d.). APC4016 air compressor owner's manual.
Identification
The APC4016 is a portable two-wheel horizontal cylinder tank with an upright handle. The model number and serial information are located on the compressor's label. The electric motor and pump are mounted above the air tank. The pressure gauge, regulated pressure gauge, pressure regulator, quick-connect air outlet, pressure release valve, and power switch are all located near the compressor controls for easy access during operation.
Technical Specifications
- Manufacturer: All-Power America
- Model Number: APC4016
- Compressor Type: Electric portable air compressor
- Peak Horsepower: 3.5 HP (CV)
- Tank Capacity: 6 gallons
- Voltage: 115V
- Amperage: 2.6A
- Phase: Single Phase (1)
- Kick-In Pressure: 80 PSI
- Kick-Out Pressure: 100 PSI
- Crankcase Oil Capacity: Approximately 16 fluid ounces
- Power Requirement: Grounded 110-115V household outlet
Additional Information
Owners Manual
All-Power America APC4016 Owner's Manual: Air compressor owners manual.pdf
Video link for: Air Compressor Maintenance
Why regular air compressor maintenance is essential:
https://aircompressors.com/news-insights... maintenance-is-essential
Video links for: Air Compressor Troubleshooting and Repair
• Step-by-step troubleshooting an air compressor with low Pressure: Low- pressure Air Compressor
• The compressor capacitor: Air Compressor Troubleshooting- Capacitor Diagnosis and Replacement
• No-start faults, low pressure, overheating, oil leaks, and condensate problems:
Air-compressor Troubleshooting
Link for: Core Elements of the Air Compressor
Air compressor basics, parts of an air compressor, and diagram of air compressor parts: Fluid Aire dynamics: What are the Parts of an Air Compressor- Diagram of Air Compressor Parts.
Maintenance Information
Routine maintenance is necessary to ensure optimal operation, maintain safety when in use, and extend the life of the air compressor.
The manufacturer recommends:
- Regular inspection for leaks. Air compressor owners manual.pdf
- Drain moisture from the tank daily to prevent it from rusting inside. Air compressor owners manual.pdf
- Test the pressure relief valve at every use. Air compressor owners manual.pdf
- Routinely check the compressor oil in the pump for proper lubrication. Air compressor owners manual.pdf
- Use SAE-20 compressor oil. Air compressor owners manual.pdf
- Change compressor oil after the first 100 hours of operation. Air compressor owners manual.pdf
Troubleshooting Resources
Common issues:
- Low pressure output or insufficient flow. Low- pressure Air Compressor
- Air leaks from fittings or regulator components. Air-compressor Troubleshooting
- Restricted check valves. Air compressor owners manual.pdf
- Circuit breaker tripping during startup. Air compressor owners manual.pdf
- Overheating due to poor ventilation or dirty cooling surfaces. Air-compressor Troubleshooting
- Motor failing to start because of low voltage, blown fuses, or check valve issues. Air-compressor Troubleshooting
Most Issues are often associated with normal wear, inadequate maintenance, and electrical supply issues.
Manufactures Support
- All-Power America Technical Support: 888-896-6881
