Up to 20% off select tools
11 Diagrams
Documents
Models
LP540
Background
The Airlessco LP540 is an airless paint sprayer suitable for portable spray application of architectural paints and coatings. It has a maximum working pressure of 3000 psi and adjustable pressure controls for performance optimization. This model is compatible with Graco conductive or grounded high-pressure airless paint sprayer hoses and Graco nozzle tips, contributing to reliable performance. To operate the LP540, it is necessary to consult Safety Data Sheets (SDS) and container labels provided with the paints and solvents.
Technical Specifications
  • Maximum working pressure: 3000 psi (21 MPa, 207 bar)
  • Power requirements: 120V AC, 60 Hz, 11A, 1 phase
  • Generator required: 3000 W minimum
  • Maximum delivery: 0.57 gpm (2.2 lpm)
  • Maximum tip size: 0.025
  • Fluid outlet NPSM: 1/4 in.
  • Noise: Sound power* 91 dBa, Sound pressure* 75 dBa
  • Wetted parts: zinc and nickel-plated carbon steel, nylon, stainless steel, PTFE, acetal, leather, UHMWPE, aluminum, tungsten carbide
Airlessco LP540 Manual
Airlessco LP460–LP690 / Allpro 510E–810E Airless Paint Sprayer Service/Operation Manual
Airlessco LP500–LP690 and AllPro 510E–810E Airless Paint Sprayer Service/Operation Manual
Airlessco LP540 Hi Boy Series B Airless Paint Sprayer Operation, Repair, and Parts Manual
Author
with
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 0
Past 7 Days: 14
Past 30 Days: 64
All Time: 2,080
