6 Diagrams
Ask a Question
There are no questions. Be the first to ask a question!
Models
24F568
Background
The Airlessco 24F568 is an airless paint sprayer designed for medium to large residential projects and light commercial buildings. It belongs to the LP series, which includes various models suitable for different applications. The device is capable of spraying a wide range of materials, including water and oil-based coatings, 100% acrylics, multi-color, stains, sealers, varnishes, and lacquers.
This paint sprayer is equipped with a reliable, pulsation-free electronic pressure control system, ensuring consistent performance. Additionally, the device features a rugged, heavy-duty chrome-plated steel hi-boy cart, making it easy to move around the job site. The Airlessco 24F568 has a maximum tip size of .023, a maximum output of .54 gpm (2.0 lpm), and a maximum working pressure of 3000 psi (207 bar). The unit is powered by a 1 hp DC motor and requires a 3000-watt minimum generator.
Technical Specifications
  • Max. Tip Size: .023
  • Max. Output: .54 gpm (2.0 lpm)
  • Max. Working Pressure: 3000 psi (207 bar)
  • Max. Hose Length: 150 ft (45 m)
  • Unit Weight: 73 lbs (33 kg) HiBoy
  • Motor: 1 hp DC
  • Unit Includes: 1/4 in x 50 ft (6.4 m x 15 m) Hose, 500 Series Gun and 517 Uni-Tip Spray Tip
  • Power Requirements: 120V AC, 60 hz, 11A, 1 phase or 230V AC, 50/60 hz, 7.5A, 1 phase
  • Generator Required: 3000 w minimum
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 24
All Time: 422
