Laptop base
This page has been tagged for revision by students in our education program.
This wiki is being worked on by hardworking students.
1 Answer 0 Score |
I have a file in my laptop and it takes most of my storage |
No Answers 0 Score |
Replacing Keyboard on an Acer Swift 5 SF514-51 |
72F8, 73HS, 780R
The Acer Swift 5 SF514-51 is a 14-inch thin-and-light laptop, a type of computer often called an ultrabook. Intel introduced the Ultrabook category in 2011 as a trademarked label for thin laptops built on its Core processors. The SF514-51 uses an Intel 7th-generation (Kaby Lake) Core i5 or i7 processor with integrated Intel HD Graphics 620. It also has up to 8 GB of DDR3 memory, an M.2 NVMe solid-state drive of up to 512 GB, and a 14-inch 1920×1080 IPS display. Spec databases list a body of aluminum and plastic. Other listed features are a fingerprint reader, a webcam, an optional backlit keyboard, an SD card reader, HDMI, USB-A and USB-C ports, and a Kensington lock slot. The intended users are students, commuters, and office workers who want a lighter laptop for web browsing, documents, video, and similar everyday work. It is not intended for gaming or other graphics-heavy work.
Acer announced the Swift 5 at IFA 2016 alongside the Swift 1, 3, and 7. At announcement, Acer listed it at 14.4 mm thick and 1,360 g, with the 14-inch display fitted into a body about the size of a 13.3-inch laptop. The reviews I found date from March to August 2017, so retail sales began in early 2017. I couldn’t find an official launch price, discontinuation date, or sales figure. Reviews came from several countries, including the UK, the Netherlands, China and Bulgaria, so it was sold in many regions under many regional SKU codes (for example SF514-51-59AV and SF514-51-75W4). The model is not known to have been subject to a recall, and I found no widely reported failure pattern. Reviews praised the build quality, portability, display and battery life. The most common complaint was the keyboard, which reviewers described as mushy with shallow key travel.
The SF514-51 belongs to Acer’s Swift line of consumer laptops, which sit above the budget Aspire line and are designed to be thinner and lighter than typical models. Within the Swift line, the Swift 5 is the middle tier between the Swift 3 and the very thin Swift 7. A LaptopMedia review described the SF514-51 as essentially an Acer Aspire S 13 with a larger screen and a somewhat higher price, so the Aspire S 13 is its closest predecessor. It was followed in late 2017 by the SF514-52T, which used 8th-generation Intel processors, weighed under 1 kg, and added a touchscreen. Later Swift 5 models (SF514-53T, SF514-54T, SF514-55) kept the sub-1 kg weight and moved to newer Intel processors. In 2023, Acer renamed the Swift 5 line to simply “Swift.”
Several details below still need checking against a physical unit.
Dimensions and weight
Processor and memory
Storage
Display
Battery
Connectivity
Other features
Sources: Notebookcheck, LaptopMedia
Not found: adapter rating, operating temperature range, and an official manufacturer spec sheet. I’d check Acer’s support page for the SF514-51 for those.
Past 24 Hours: 2
Past 7 Days: 10
Past 30 Days: 74
All Time: 3,822
