Up to 20% off select tools
Guides
Documents
Tools
These are some common tools used to work on this device. You might not need every tool for every procedure.
Background
The Acer Spin 7 SP714-51 is a 2-in-1 convertible laptop released by Acer in 2016. This laptop is an ultrathin and portable device for business and personal use, retailing when new for about $950. The Spin 7's construction is durable and the interior boasts an impressive touchpad and keyboard with a premium feel.
Identification
The model number can be located on the underside of the laptop on a black horizontal label. There are submodels of this laptop with different hardware configurations; to find your exact hardware configuration, note the last four digits of your model number: SP714-51-XXXX. Searching up this model number will let you know the exact hardware inside your configuration.
Technical Specifications
  • Screen: 1920 x 1080p, 14" Touchscreen
  • GPU: Intel HD Graphics 615 (Integrated)
  • CPU:
    • MO24, M4YD - Intel Kaby Lake Core i7-7Y75 CPU
    • MO9D – Intel Kaby Lake i5-7Y54
  • Ports: 2 x USB 3.1, mic/headphone
  • Operating System: Windows 10 Home
  • Storage: 256GB mSATA SSD
  • Memory: 8GB RAM
  • Battery Life: 8 Hours
  • Weight: 1.2Kg (2.64 lbs)
  • Size: 324 mm or 12.78” (w) x 229 mm or 9.04” (d) x 10.9 mm or 0.43” (h)
Additional Information
Author
with
Austin DeSousa
101 Reputation
0 Guides authored
Past 24 Hours: 2
Past 7 Days: 8
Past 30 Days: 41
All Time: 2,403
