Up to 20% off select tools
Guides
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Tools
These are some common tools used to work on this device. You might not need every tool for every procedure.
Background
The Acer Chromebook CB315-5H-P8HK is the model of the Acer Chromebook 315 series released in the early 2020s. The device is designed for productivity and optimized for video calling and education based work. This version upgraded from earlier models of the 315 with a more efficient processor, modern connectivity, and enhanced display quality.
The design of the Acer Chromebook CB315-5H-P8HK is made up of recyclable materials and an energy efficient design to embody the company’s priority for waste reduction.
Users most consistently report issues with battery life, power storage, and the device running slower over time. Many find that after a significant amount of time with the device it becomes problematic, but out of box it has about 13 hours of battery life and runs well for its intended purposes in browser-based work.
Sources
Acer Chromebook 315
Identification
The Acer Chromebook CB315-5H-P8HK can be identified by its 15.6 inch display, it is carried in a silver case color, and black keyboard with no backlight. The model number can be located on the bottom of the laptop, right above the barcodes.
Technical Specifications
General
  • Operating System: ChromeOS
  • Form Factor: 15.6-inch Chromebook laptop
 Processor (CPU)
  • Manufacturer: Intel
  • Model: Intel N100 (or similar N-series depending on config)
  • Cores: Quad-core
  • Max Speed: Up to ~3.4 GHz
 Graphics (GPU)
  • Integrated: Intel UHD Graphics
  • Memory: Shared system memory
Display
  • Size: 15.6 inches
  • Resolution: 1920 × 1080 (Full HD)
  • Panel Type: IPS LCD
  • Finish: Anti-glare (ComfyView matte)
  • Refresh Rate: 60 Hz
 Memory (RAM)
  • Type: LPDDR5
  • Capacity: Typically 4 GB (varies by configuration)
 Storage
  • Type: eMMC / Flash storage
  • Capacity: 64 GB (some configs up to 128 GB)
  • Expandable: microSD card slot
 Connectivity
  • Wi-Fi: Wi-Fi 6 / 6E (802.11ax)
  • Bluetooth: 5.1 or newer
 Ports
  • 2 × USB 3.2 Type-A
  • 2 × USB 3.2 Type-C
  • No Ethernet (RJ-45)
 Camera & Audio
  • Webcam: 1080p Full HD
  • Microphone: Yes
  • Speakers: Dual speakers
 Input
  • Keyboard: Full-size (no backlight)
  • Touchpad: OceanGlass touchpad
 Battery & Power
  • Battery Type: Lithium-ion
  • Battery Life: Up to ~12.5 hours
  • Charger: ~65W USB-C
 Physical Specs
  • Weight: ~3.7 lbs (1.7 kg)
  • Dimensions: ~14.4" × 9.6" × 0.82"
  • Color: Silver
Other Features
  • No fingerprint reader
  • Fanless design (quiet operation typical for this series)
  • Eco-friendly OceanGlass touchpad
Sources
Acer Chromebook 315 (CB315-5H/CB315-5HT) - CB315-5H-C4Z5 Tech Specs
Additional Information
Acer Chromebook 315
TeciSoft
Walmart Business
Acer Chromebook User Manual
Author
with
Lylah Thibeault
51 Reputation
0 Guides authored
Past 24 Hours: 6
Past 7 Days: 10
Past 30 Days: 30
All Time: 282
