Up to 20% off select tools
Guides
Documents
Tools
These are some common tools used to work on this device. You might not need every tool for every procedure.
Background
The C710-2847 runs Google's Chrome OS, a relatively new, cloud based operating system. Chrome OS is built to be fast, starts up quickly, and doesn't slow down over time. It has security features built in to keep your files safe while on the web. Because Chrome OS is cloud based, files are easily accessible between computers, and the Chromebook is always up to date.
Identification
Your specific model number can be found on sticker on the bottom of the device. It is in the top left corner and in the form C710-XXXX. Acer's C710 series has twelve unique models that share the same exterior design. These devices can be distinguished from other netbook devices by the Acer and Chrome logos on the lid. All the devices are slate gray with a black bezel, bottom cover, and chiclet keyboard. The line was released in December 2012.
Specifications
Numbers in parentheses correspond to the last four characters in the model number and identify each version of the device.
Display:
  • 11.6 in (295 mm)
  • 1366 x 768 pixel resolution
  • Backlit Active Matrix TFT LCD
Storage:
  • 16GB SSD (2411, 2457, 2481, 2688, 2815, 2826, 2833, 2834, 2856)
  • 320GB HDD (2055, 2847)
  • 500GB HDD (2606)
Processor
  • Intel Celeron 847 1.10Ghz (2055, 2457, 2606, 2688, 2815, 2826, 2833, 2847, 2856)
  • Intel Celeron 1007U 1.50Ghz (2411, 2481, 2834)
Memory
  • 2GB (2411, 2606, 2826, 2833, 2834, 2847, 2856)
  • 4GB (2055, 2457, 2481, 2688, 2815)
Wireless Connectivity
  • IEEE 802.11 a/b/g/n
Graphics and Video
  • Intel HD Graphics
Battery
  • AL12B32 4-cell Li-ion (14.8V; 2500mAh; 37Wh) (2055, 2411, 2457, 2481, 2688, 2833, 2834, 2847, 2856)
  • AL12X32 6-cell Li-ion (11.1V; 5000mAh; 56Wh) (2606, 2815, 2826)
Ports
  • Three USB 2.0
  • 3.5mm headphone jack
  • Ethernet RJ45
  • VGA output DE-15
  • HDMI output
  • DC power input
  • SD card reader
  • Kensington lock port
Dimensions
  • height: 1.1 in
  • width: 11.2 in
  • depth: 8.0 in
  • weight: 3.04 lbs (2055, 2411, 2457, 2481, 2688, 2833, 2834, 2847, 2856)
  • weight: 3.2 lbs (2606, 2815, 2826)
Upgrades
You can safely and easily upgrade these components.
  • Hard Drive: SATA compatible 2.5 in drive
    • An SSD is recommended over an HDD due to speed improvements; however, an SSD drive is more expensive.
    • The recommended lowest capacity is 16GB.
  • Memory: DDR3 SDRAM SO-DIMM
    • System memory can be upgraded to 16 Gio.
    • An individual memory module cannot exceed 8 Gio.
Additional Information
Acer C7 Chromebook C710 Produktblatt
Author
with
Adam Whitmarsh
1,068 Reputation
1 Guide authored
Cal Poly, Team 13-3, Forte Fall 2013 Member of Cal Poly, Team 13-3, Forte Fall 2013
CPSU-FORTE-F13S13G3
5 Members
84 Guides authored
Past 24 Hours: 3
Past 7 Days: 18
Past 30 Days: 43
All Time: 47,912
