Up to 20% off select tools
Documents
Background
The Acer Chromebook 315 is designed for mobile life, professionals, small business, school education, and commercial enterprise, built-in with a fast CPU and long battery life. It comes with 32 or 64 GB of internal disk space and 4 or 8 GB of high-bandwidth RAM to smoothly run multiple applications and browser tabs all at once. 64GB flash memory is ideal for mobile devices and applications because it provides enhanced storage capabilities, data management, quick boot-up times and support for high-definition video playback.
With a 15.6” anti-glare screen, it features an HD 720p front-facing camera with a built-in microphone, allowing for smooth and clear conversations held online, and a touch screen that support zooming in and out of tabs.
Nearly 20 million chromebooks are sold each year and it is a widely used device, especially in educational and business settings. It's consumer focused device is powered by an Intel Celeron N4120 with a base clock speed of 1.1 GHz. Reviewers find the laptop offers good value for the price and easy to use, high appreciation for its great battery life which allows them to work for a full day, and satisfaction with the screen size and quality. However, some customers dislike the game functionality, used for gaming apps, and have mixed opinions on the laptop's functionality and camera quality.
The base models of the Acer Chromebook 315 can struggle under load due to their low-end processors, causing slow performance; the 4GB RAM version experiences frequent slowdowns when multiple tabs are open. Some other issues many user have reported are:
  • Washed-out colors on the display, making text and images appear less sharp. Additionally, the screen brightness is poor (~220 nits), making it difficult to use in bright environments.
  • Since some models come with a touchscreen, users have encountered issues with laggy or unresponsive touch input.
  • Another common issue is battery drain, even when the laptop is not in use or turned off, suggesting that the battery is weaker compared to other laptops.
  • The hinges are weak, which is problematic given the plastic chassis. The overall build quality is fragile, and users have reported screen wobbling over time due to the lack of strong hinge support.
Sources:
Identification
The Acer Chromebook 315 (CB315-3H/CB315-3HT) has a plastic shell that looks like it might be metal and the Acer logo, ACER, located at the bottom of the screen’s rim. The screen is 15.6” with a fully HD touch screen. On the left side of the laptop, there are two USB 3.1 Type-C ports and two USB 3.0 Type A ports, which are used for data transfer, video streaming, and battery charging.
The Chromebook 315 is relatively thick at 0.79 inch and feels heavier than it looks, weighing at 3.65 pounds.
Sources:
Technical Specifications
Acer Chromebook 315 (2023) - Specifications
Class: Chromebook
Processor: Intel Pentium Silver N6000
Processor Speed: 1.1 GHz
RAM (as Tested): 8 GB
Boot Drive Type: eMMC Flash Memory
Boot Drive Capacity (as Tested): 64 GB
Screen Size: 15.6 inches
Native Display Resolution: 1,920 x 1,080
Panel Technology: IPS
Variable Refresh Support: None
Screen Refresh Rate: 60 Hz
Graphics Processor: Intel UHD Graphics
Wireless Networking: 802.11ax, Bluetooth
Dimensions (HWD): 0.79 x 14.4 x 9.6 inches
Weight: 3.65 lbs
Operating System: Chrome OS
Tested Battery Life: 7 hours, 14 minutes
Source: PCMAG
Additional Information
Author
with
tayola
10,505 Reputation
44 Guides authored
Kid fixers Member of Kid fixers
Community
229 Members
2,196 Guides authored
Past 24 Hours: 1
Past 7 Days: 20
Past 30 Days: 81
All Time: 2,121
