Up to 20% off select tools
Medical Equipment
Neither iFixit nor this repair information is endorsed by or affiliated with the medical device manufacturer.
No Image
This wiki is missing a device image. Help improve this page by uploading one!
Ask a Question
There are no questions. Be the first to ask a question!
Documents
FreeStyle Freedom Lite Owner's Booklet
Background
The FreeStyle Freedom Lite is a traditional fingerstick blood glucose monitoring system manufactured by Abbott Diabetes Care. Originally launched and made available in the United States in April 2008, it was considered a companion model for the FreeStyle Lite meter as both used the same technology and test strips. However, the Freedom Lite was considered better due to its larger numeric display and more comfortable design.
The FreeStyle Freedom Lite is for people with diabetes to test at home, and for healthcare professionals. It's designed to monitor the effectiveness of a patient's diabetes control program without requiring coding. Its internal memory can store up to 400 test results, including the time and date, and also provides averages for up to one month. These tests and results are fast and accurate. It requires at least five seconds and only a 0.3 Microliter blood sample from either your fingertips, palms, upper arms, thighs, calves, or hand.
The FreeStyle Freedom Lite weighs roughly 1.4 to 1.6 ounces and measures 3.3 inches (L) x 2.0 inches (W) x 0.63 inches (H). It requires one 3-volt lithium coin cell battery and lasts up to 1000 tests. This makes it easy for on-the-go glucose monitoring.
However, unlike its previous models, the Freedom Lite did not have a port light or backlight, with the trade-off being a larger and comfortable design. While not all users were affected, FreeStyle Lite test strips were subject to a recall in November 2013. Some users reported a blank screen or “SET” error. These issues are usually caused by the test strip, battery, or meter.
Source: All About FreeStyle Lite Glucose Meters and Test Strips
Identification
The FreeStyle Freedom Lite is a compact, lightweight, and simple glucose monitor designed for basic and easy-to-use functionality. It is tear-drop shaped, small enough to fit in the palm of your hand. The plastic cover is made of a smooth, light blue color, along with three grey buttons on the front and a large numeric display. The front displays " FreeStyle Lite". It doesn't have a port light or backlight. The model number is on the back of the device.
Technical Specifications
  • Assay method: Coulometric electrochemical sensor
  • Automatic shutoff: 2 minutes of inactivity
  • Battery life: 1000 tests
  • Calibration: Plasma equivalent
  • Haematocrit: 15% to 65%
  • Measurement units: mmol/L
  • Meter storage temperature: – 4° to 140° F (–20° to 60° C)
  • Memory: 400 blood glucose and control solution tests with date and time
  • Operating relative humidity: 5% to 90% (non-condensing)
  • Operating temperature: 40° to 104° F (4° to 40° C)
  • Power source: One CR 2032, 3V lithium battery, replaceable
  • Result range: 1.1 to 27.8 mmol/L
  • Sample: Fresh capillary and venous whole blood samples
  • Sample size: 0.3 microliter (300 nanoliters)
  • Size: 2.0 in (w) x 3.3 in (l) x 0.63 in (d) 5.1 cm (w) x 8.4 cm (l) x 1.6 cm (d)
  • Weight: 1.4 to 1.6 oz. (39.7 to 45.4 g) including battery
Troubleshoot
If you have trouble with your FreeStyle Freedom Lite, refer to the troubleshooting page.
Additional Information
Abbott Freestyle Site
FreeStyle Freedom Lite Owner’s Booklet
Cleveland Clinic Continuous Glucose Monitoring
FreeStyle Freedom Lite on Amazon
FreeStyle Lite Blood Glucose Test Strips Product Information
Abbott FreeStyle Freedom Lite 自己検査用グルコース測定器 取扱説明書
FreeStyle Freedom Blood Glucose Monitoring System Owner's Booklet (EN, ES)
Author
with
eCuration
478,744 Reputation
396 Guides authored
iFixit Member of iFixit
Staff
119 Members
72,966 Guides authored
Past 24 Hours: 0
Past 7 Days: 13
Past 30 Days: 61
All Time: 637
