Guides
Documents
Tools
These are some common tools used to work on this device. You might not need every tool for every procedure.
Background
The APC Smart-UPS is a high-end uninterruptible power supply that is geared towards servers, storage, and network closets. It also provides protection against lightning strikes, power sags, brownouts, and surges. It comes with a preinstalled Network Management Card for monitoring and management, as well as a PowerChute Network Shutdown which allows for graceful shutdown of physical servers, virtual machines, and HCI clusters. Additionally, the UPS offers cloud-based remote monitoring for power, UPS firmware upgrades, diagnostics, and email notifications.
Identification
The UPS can be identified by model number SMT1500RM2UC. To find the model number, remove the front bezel and look for a sticker to the right of the display. The sticker has the model number and serial number.
Technical Specifications
Battery Type
  • Lead-Acid
Voltages
  • Input Voltage
    • Main: 120V
    • Other: 110/125 V
  • Output Voltage
    • Main: 120 V
    • Other: 110/125 V
Connections
  • Input: NEMA 5-15P
  • Output: 6 NEMA 5-15R
Communication Port Type
  • SmartConnect Ethernet port
  • SmartSlot
  • USB
  • Serial
Input
  • Efficiency at full load
    • 75...154 V adjustable
    • 82...144 V
  • Input Frequency: 50/60 Hz +/- 3 Hz auto-sensing
Output
  • Harmonic distortion: less than 5%
  • Maximum configurable power: 1440 VA
  • Max configurable power (Watts): 1000 W
  • Transfer time: 6ms typical, 10ms maximum
  • Topology: line interactive
  • Waveform type: Sine wave
  • Output frequency (sync to mains): 50/60 Hz +/- 3 Hz sync to mains
Physical
  • Dimensions (W x D x H): 17.01 x 18.78 x 3.39 in (43.2 x 47.7 x 8.6 cm)
  • Net weight: 58.42 lb (26.5 kg)
  • Mounting location: front
  • Mounting preference: lower
  • Mounting mode: rack-mounted
Additional Information
APC Device Page
APC Support
Spencer Day
207,230 Reputation
1,266 Guides authored
iFixit Member of iFixit
Staff
121 Members
72,907 Guides authored
Past 24 Hours: 1
Past 7 Days: 24
Past 30 Days: 92
All Time: 1,521
