Up to 20% off select tools
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Models
This category covers 2014, 2015, 2016, 2017 Cadillac CTS models.
Chassis, Mass Reduction & Dynamics
  • The Alpha Platform Transition: By migrating to the Alpha architecture, the third-generation CTS shed up to 244 lbs (111 kg) compared to its predecessor. This was achieved via an aluminum-intensive front suspension layout, aluminum engine cradles, and thin-wall high-strength steel stamping. The structural configuration resulted in a near-perfect 50/50 front-to-rear weight distribution.
  • Magnetic Ride Control (Generation 3): Standard on the V-Sport and optional on upper trims, the twin-wire coil MRC design responded 40% faster than the previous generation. It sampled road inputs every millisecond and could adjust damper stiffness across a wide range in the time it took the vehicle to travel just one inch at 60 mph.
  • Braking Hardening: All mid-tier and high-tier trims featured standard Brembo front braking systems with four-piston fixed aluminum calipers. The rotors used GM's proprietary Ferritic Nitro-Carburizing (FNC) anti-corrosion treatment, a thermochemical process that doubles rotor lifespan by reducing rust scaling and brake judder.
Powertrain & Mechanical Engineering
2.0L Twin-Scroll Turbocharged I4 (LTG)
  • Architecture: 1998cc dual-overhead cam (DOHC) inline-four with a sand-cast aluminum block and structural bedplate.
  • Output: 272 hp @ 5,500 rpm / 295 lb-ft of torque @ 1,700–5,500 rpm.
  • Engineering: Features a twin-scroll turbocharger paired with an air-to-air intercooler. The twin-scroll layout segregates exhaust pulses from cylinders 1 and 4 from cylinders 2 and 3, reducing lag and creating rapid boost pressure down low.
3.6L Twin-Turbo V6 (LF3) — V-Sport Exclusive
  • Architecture: 3564cc DOHC V6 variant heavily modified for forced induction, featuring a reinforced block casting, forged steel connecting rods, and a lower 10.2:1 compression ratio.
  • Output: 420 hp @ 5,750 rpm / 430 lb-ft of torque @ 2,500–5,500 rpm.
  • Induction Details: Utilizes vacuum-actuated wastegates and a unique single, centrally located water-to-air intercooler mounted directly atop the intake plenum. This layout shortens the intake tract volume by more than 60% compared to traditional twin-intercooler designs, providing sharp throttle response.
Drivetrain & Electronic Differential (eLSD)
  • Transmission Architecture: Early 2014 RWD models introduced an Aisin 8-speed automatic, while AWD versions retained the Hydra-Matic 6-speed. By 2016, GM standardized its own Hydra-Matic 8L45/8L90 8-speed automatic transmissions across the entire lineup, reducing parasitic mechanical losses and optimizing gear-ratio steps.
  • Electronic Limited-Slip Differential (V-Sport): The eLSD featured an electronically controlled clutch pack that varied the locking torque in milliseconds based on lateral acceleration, wheel slip, and steering inputs. This allowed the car to maintain an open differential state for smooth low-speed turning, while locking under hard cornering to maximize power delivery across the rear track.
Author
with
oldturkey03
867,026 Reputation
123 Guides authored
Global Fixers Member of Global Fixers
Community
74 Members
3,048 Guides authored
Past 24 Hours: 12
Past 7 Days: 39
Past 30 Days: 113
All Time: 624
