Up to 20% off select tools
Guides
Documents
Models
This category covers 2007, 2008, 2009, 2010, 2011 Cadillac CTS models.
Chassis, Architecture & Vibrational Isolation
  • Sigma II Evolution: The Sigma II platform increased the track width by 2 inches and structural torsional rigidity by roughly 25% compared to the first generation. It utilized structural adhesives alongside spot welds to create a highly rigid passenger cell, dampening structural resonance and improving crash-test performance.
  • Dual-Isolate Subframes: The engine, front suspension, and steering gear were mounted to a hydroformed steel front subframe that isolated the unibody via large hydraulic bushings. The rear multi-link suspension used an aluminum subframe isolated with tuned rubber mounts to eliminate rear-tier gear whine (NVH).
  • Braking Packages (JE5 vs J55):
    • JE5 Base Performance: Equipped with dual-piston front sliding calipers and 321mm ventilated rotors.
    • J55 Heavy Duty: Included in the Performance and Summer Tire packages, this upgraded the vehicle to larger 345mm front rotors and high-thermal-capacity compound pads, requiring the clearance of factory 18-inch or 19-inch wheels.
Powertrain & Mechanical Engineering
3.6L Direct Injection V6 (LLT)
  • Architecture: 3564cc 24-valve DOHC V6, 60-degree block with an aluminum cylinder case and integrated structural bedplate.
  • Output: 304 hp @ 6,400 rpm / 273 lb-ft of torque @ 5,200 rpm.
  • Injection Dynamics: This engine transitioned from Port Fuel Injection to Direct Injection (DI). By spraying atomized fuel directly into the combustion chamber at pressures up to 1,740 psi, the fuel charge cooled the intake air. This allowed for a significantly higher 11.3:1 compression ratio, boosting power and cold-start emissions control without causing pre-detonation (knocking).
3.0L Direct Injection V6 (LF1) - Introduced 2010
  • Architecture: Down-sized 2994cc high-feature V6 variant utilizing a shorter stroke (85.6mm vs 99mm on the 3.6L).
  • Output: 270 hp @ 7,000 rpm / 223 lb-ft of torque @ 5,700 rpm.
  • Role: Replaced the older 210 hp 2.8L LP1 port-injected base engine, utilizing an 11.7:1 compression ratio to maximize efficiency at high engine speeds.
Drivetrain & AWD Integration
  • Active AWD (BorgWarner): The optional active all-wheel-drive system utilized a BorgWarner ITM 3e transfer case featuring an electronically controlled, multi-plate wet clutch pack. Under nominal dry traction conditions, torque was split 25/75 front-to-rear to preserve the handling characteristics of a rear-wheel-drive sedan. If the rear wheel speed sensors detected slip, the system could smoothly redirect up to 100% of available torque to the front axle within milliseconds.
  • Transmission Options: Power was funneled through either an Aisin AY6 6-speed manual or the Hydra-Matic 6L50 6-speed automatic transmission, which incorporated adaptive shift algorithms and manual tap up/tap down paddle shifting.
The Second-Gen V-Series Apex (2009–2011 CTS-V)
In 2009, the CTS-V variant was re-engineered utilizing track-validated hardware:
  • LSA 6.2L Supercharged V8: Derived from the Corvette ZR1’s LS9, this pushrod V8 utilized a 1.9L Eaton Twin Vortices Series (TVS) roots-type supercharger delivering 9 psi of boost, outputting 556 hp and 551 lb-ft of torque.
  • Magnetic Ride Control (MRC): Featured Delphi’s dual-cavity Magnetorheological dampers. These struts filled the fluid passages with microscopic iron particles; by altering the electromagnetic current inside the damper, the system adjusted fluid viscosity and changed damping rates at all four wheels independently up to 1,000 times per second.
  • Braking & Wheels: Massively anchored by Brembo 6-piston front fixed calipers grabbing 380mm two-piece rotors, and 4-piston rears with 373mm rotors, housed inside forged aluminum wheels wrapped in Michelin Pilot Sport PS2 tires.
Author
with
Arthur Shi
354,348 Reputation
938 Guides authored
iFixit Member of iFixit
Staff
119 Members
72,966 Guides authored
Past 24 Hours: 2
Past 7 Days: 15
Past 30 Days: 49
All Time: 2,403
