Up to 20% off select tools
Documents
Models
This category covers 1987, 1988, 1989, 1990, 1991 Ford Bronco models.
Background and Identification
The Ford Bronco is a line of SUVs (sport utility vehicles) produced by Ford between 1965 to 1996. The Bronco was the first SUV marketed by Ford and was originally a compact design based on an independent chassis. The Ford Bronco II was a compact SUV based on the Ford Ranger between 1984 and 1990 and was replaced by the Ford Explorer. For the 2021 model year, Ford reintroduced the Bronco SUV with both two- and four-door variants. In 2021, the Bronco was marketed as a mid-sized competitor to the Jeep Wrangler.
The fourth-generation Ford Bronco was released in 1987 with the introduction of the eighth-generation Ford F-Series. The fourth-generation Bronco shares its front sheet metal with the F-150. The Bronco gained a reshaped front bumper, flatter front grille, composite headlights, and a reshaped hood. The vehicle also gained rounded wheel openings in the fenders. The Bronco’s interior added redesigned front seats, door panels, dashboard, controls, and instrument panels. Anti-lock brakes (ABS) became standard with the 1987 model. The 1987 model was also available with a push-button control option for its four-wheel-drive model.
Ford vehicles can be identified by the Ford emblem, which depicts the name “Ford” in a cursive font. Bronco SUVs include the name “Bronco” either in capital letters or cursive letters as well as the Bronco emblem, which depicts a bucking horse.
Technical Specifications
Body and Chassis:
  • Class: Full-size SUV
  • Body Style: 3-door SUV
Powertrain:
  • Engine:
    • 300 cu in (4.9 L) Straight-6
    • 302 cu in (4.9 L) 302 V8
    • 351 cu in (5.8 L) Windsor V8
  • Transmission:
    • 5-speed M5OD-R2 manual
    • 3-speed C6 automatic
    • 4-speed AOD automatic
    • 4-speed E4OD automatic
Dimensions:
  • Wheelbase: 2,700 mm (106.3 in)
  • Length: 180.5 in (4,580 mm)
  • Width: 79.1 in (2,010 mm)
  • Height:
    • 1987–1989: 74.0 in (1,880 mm).
    • 1990–1991: 74.5 in (1,890 mm)
Additional Information
Ford, Lincoln, Mercury & Merkur Torque Converter Replacement and Cooling System Cleaning Service Tip
Metra 99-5510 Ford/Jeep/Lincoln/Mercury 1975-2000 Radio Kit Installation Instructions
Ford Technical Service Bulletin 00-23-10 Transmission Fluid In-Line Filter Kit
Ford ZF S5-42 Manual Transmission Troubleshooting Guide TSB 90-15-11
Ford Article 95-12-1: Urethane Mounted Windshield Glass Material Usage Service Tip
Ford Article 96-22-1: Windshield and Interior Glass Fog/Film
Ford Approved Air Conditioning Flushing Procedures Service Tip TSB 95-18-4
Ford A/C Spring Lock Coupler O-Ring Removal Service Tip TSB 95-2-2
Ford Article 98-24-6 Service Bulletin: New Terminal Grease
Ford Technical Service Bulletin 95-8-2 Wiper Motor Upgraded Service Kits
Ford Technical Service Bulletin 98-26-2 Fuel Volatility Driveability Concerns
Ford A/C Refrigerant Filtering After Compressor Replacement Service Bulletin 98-12-5
Ford Technical Service Bulletin 01-15-7 Transmission Fluid Usage
Ford Article 99-19-6: A/C Refrigerant Identification and Air Purging
Ford Article 95-6-1: Paint Iron Particle and Acid Rain Decontamination
Front and Rear Light Axle Parts, Kits and Applications Catalog, 1978–1998
Spicer Drivetrain Components Axle General Information (XGI)
Author
with
Sam Goldheart
478,973 Reputation
538 Guides authored
iFixit Member of iFixit
Staff
119 Members
72,966 Guides authored
Past 24 Hours: 3
Past 7 Days: 18
Past 30 Days: 75
All Time: 5,225
