Up to 20% off select tools
Repair, disassembly, and troubleshooting information for the Infinix Smart 10 Android smartphone, including model X6725.
Why my system charge don't work
My charger system does not work
Add a comment
1 Answer
@selinatimo64569 we really would need more specific information about what is going on with your charging system. Start of with a few generic checks.
First check your charger. Make sure it has proper output. Then check your charging cable. Check to make sure connectors are not bend etc. After that, check the charging port. Clean it of any debris etc, use a few puffs of air to clean it out. If none of this works, get a USB ammeter and see if your phone draws any amperage from the charger. If it does not it is possible that this is a charging port issue or a bad battery.
To check the charging port, use a voltmeter and measure the voltage on your battery connector. Next plug your phone charger in. Now measure the voltage on your battery connector. That voltage will have to have increased. IF not then the issue is either the port or the charging circuit.
Check the flex cable coming from the charging board to the main board. Check that for micro tears and corrosion and proper connection to the boards. I suggest that you start with a new battery if any of the above did not work. After that it's the charging board and flex cables.
Since iFixit doesn't yet have a specific guide for that, use something like this video to work on your phone
While you work on your phone, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person who has the same issues with their device. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Repair is War on Entropy!
Add a comment
Add your answer
Selina Timoth mwasile will be eternally grateful.
Past 24 Hours: 8
Past 7 Days: 14
Past 30 Days: 28
All Time: 28
