Battery is not recognized... 'Sometimes'!
The laptop was previously water damaged and shorted the old battery, we have replaced the battery connector and cleaned the entire area that was affected, there is no visible corrosion. We got it back up and 'running' and we are getting positive (Correct) reading from all power related components yet the laptop didn't always find a battery..... Reset everything etc, baffled. Auto boots when the charger is connected (Usual).... battery icon is sometimes there but didn't charge & or isn't there at all..... odd behavior. Tested 3 with good batteries, results are all the same. @oldturkey03
I just let it on charger, and after 20 minutes or so, suddenly it IS charging and reports no issues... and then after another 30 minutes we get a battery service message come up but CB displays no issues. Unplug charger, cuts out. this is odd.
sudo nvram -c gives an error clearing firmware variable fmm-mobilee-token-FMM- xxxxxxxx etc..... Disconnected the charger, laptop now stays on, but no battery is detected... cannot seem to reset anything with Key combos on bootup, but all keys are functioning OK when laptop is turned on.
2 Comments
Well you can checkout the following thread: https://discussions.apple.com/thread/254...
by Jhon Bing Share
The 3 Batteries that we are using are all good, the apple thread is of no help whatsoever. Your 'answer' should be a comment. @danj please remove this answer thx.
by livfe Share
