Up to 20% off select tools
Earbuds released in 2022, featuring Bluetooth 5.2 and an 8 hour battery life.
Right Side earbud doesn't work properly
Right earbuds doesn't work but left one work fine
Score 1
Add a comment
1 Answer
Most Helpful Answer
I asked FixBot your question with its answer in italics. Be aware of Ai mistakes. If you decide to disassemble yours, review the Guides section on ear bud and charging case disassembly. I'm presuming your ear buds are out of warranty.
"Right earbuds doesn't work but Ieft one works fine."
To fix an issue where only the left JBL Wave Beam earbud works while the right one does not, try cleaning the charging contacts, performing a factory reset, and re-pairing the earbuds 1.
Here are the troubleshooting steps to resolve the issue:
  1. Clean the Charging Contacts: Check the metal charging pins on the right earbud and inside the charging case for earwax, dust, or debris. Clean them gently with a dry cotton swab to ensure the earbud is making proper contact and charging.
  2. Verify Battery & Charging Status: Place the right earbud back into the case and make sure its charging LED lights up. You can also connect to the JBL Headphones app to check if the right earbud is recognized and reporting battery level.
  3. Perform a Factory Reset: Place both earbuds into the charging case and follow the factory reset procedure 2 to resync the left and right units.
  4. Forget and Re-Pair: Go to your device's Bluetooth settings, select "Forget" or "Unpair" the JBL Wave Beam, turn your Bluetooth off and back on, and then pair the earbuds to your device again 1.
File
JBL Vibe Beam Quick Start Guide
•Page 11•36 pages•2.1 MB
Sources:
1 Earbuds One Side Not Working
2 JBL Vibe Beam Quick Start Guide·36 pages
Score 2
Add a comment
Add your answer
muhammad ibrahim will be eternally grateful.
Past 24 Hours: 4
Past 7 Days: 26
Past 30 Days: 71
All Time: 71
