A lightweight notebook style computer created by ASUS. Also called a VivoBook 14
¿Why it doesn't start up?
My laptop stopped displaying any image and stopped charging the battery. The battery LED is blinking orange.
I have tried resetting the BIOS, but that did not work either.
I managed to reach the login screen once, but after shutting it down and turning it back on, the same problem continued.
Add a comment
1 Answer
blinking orange means low battery (below 10%) try removing the battery then plugging it in and turning it on. Assuming you didnt charge it first if you did not charge it then charge it for like 5 hours then try to turn it on.
2 Comments:
Una luz naranja parpadeante indica batería baja (menos del 10 %); intente retirar la batería, conectar el dispositivo a una fuente de alimentación y encenderlo. Si no lo había cargado previamente, cárguelo durante unas 5 horas y luego intente encenderlo.
by
No funcionó, ya compré otra batería y el problema del led naranjas se resolvió, pero sigue sin mostrar imagen
by
Add a comment
Add your answer
Luis Angel Franco Peña will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 30
Past 30 Days: 30
All Time: 30
