3.5 CU. FT. Top-Load Washer with Dual Action Agitator. Released 2016.
How do I clean the machine's drain
Does this machine have a drain/filter assembly that could be cleaned; I have a dog that sheds.
Add a comment
1 Answer
Chosen Solution
Hi @michaelhoo92281
There is a drain filter located at the bottom of the basket but it's not considered to be user removable.
You would have to remove the drain pump from the machine and check that there's no blockage in the hose connected to the input to the drain pump, in the drain pump itself or in the drain hose leading to the house drain pipe.
Score 1
Add a comment
Add your answer
Michael Hood will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 11
Past 30 Days: 56
All Time: 56
