Released 2020 with Snapdragon 720G SOC Sold in India as the Note 9 Pro Max
My phone don't charge
My phone didn't charge
Add a comment
1 Answer
Most Helpful Answer
@sheilahlopez there are multiple reasons why it may not charge. First check your charger. Make sure it has proper output. Then check your charging cable. Check to make sure connectors are not bend etc. After that, check the charging port. Clean it of any debris etc, use a few puffs of air to clean it out. If none of this works, get a USB ammeter and see if your phone draws any amperage from the charger. If it does not it is possible that this is a charging port issue or a bad battery.
To check the charging port, use a voltmeter and measure the voltage on your battery connector. Next plug your phone charger in. Now measure the voltage on your battery connector. That voltage will have to have increased. IF not then the issue is either the port or the charging circuit.
Also check the flex cables coming from the charging board to the main board. CHeck that for micro tears and corrosion and proper connection to the boards. I suggest that you start with a new battery if any of the above did not work. After that, it's the charging board and flex cables.
Score 1
Add a comment
Add your answer
Sheilah Lopez will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 15
Past 30 Days: 42
All Time: 65
