Replacement battery for HP Omen X doesn't work
I have an HP Omen X 2S 15-dg0020nr. I just replaced its old/original genuine HP battery with an iFixit replacement battery, which appears to be made by BTI as a direct compatible replacement. I charged the laptop to 100% and kept the AC adapter attached for another 2 hours per iFixit's instruction. When trying to run the computer on battery power, it just shuts down within a minute or so. I have all the latest BIOS, firmware, drivers, everything. If I put the worn out original HP battery back in the laptop, everything works, even though the old HP battery has reduced capacity. If I put the new iFixit BTI battery in the laptop, it just shuts down within a minute or so, even in BIOS, let alone in Windows.
After days of diagnostic work, having tried 3 different 3rd party aftermarket batteries, here's my conclusion: 3rd party batteries such as BTI batteries are "physically compatible" with the HP Omen X 2S 15-dg0020nr, but they are incompatible at the firmware level. They might work with less demanding laptops, but not with high-wattage dual screen HP Omen X laptops. Here's what I think happens:
  • SMBus handshake failure: The BTI/aftermarket controller passes basic detection but fails to properly report real-time telemetry (such as cell temperature or instantaneous wattage draw) back to the laptop's EC.
  • Hard shutdowns: When the system switches from AC adapter power to battery power, the EC detects an unsupported or out-of-spec power reading from the aftermarket BTI gas-gauge chip and triggers a hard shutdown within seconds to protect the dual-screen motherboard.
To make matters worse, even if I try to use the laptop with the AC adapter while 3rd party battery is installed, the EC trips the system's BD PROCHOT safety signal because it doesn't recognize the battery as a genuine HP battery, which throttles the CPU clock speed down to 0.8 GHz and locks it there, rendering the laptop so sluggish it becomes practically useless.
If you know a workaround other than buying a genuine HP from eBay (no inventory elsewhere), or having to re-cell the battery (micro-soldering 6 new pouch cells into the old battery pack, a difficult and potentially dangerous task), I would love to hear your thoughts.
Add a comment
1 Answer
have u tried powercfg - the built-in Windows command-line tool used to control system power plans, manage sleep states, and diagnose battery or energy efficiency problems. It must be run from an elevated Command Prompt or PowerShell window for administrative commands.
Common Commands and Usage
  • Generate Battery Health Report: Type powercfg /batteryreport to create an HTML file detailing your laptop's design capacity versus full charge capacity over time. [1]
  • Analyze Energy Efficiency: Type powercfg /energy to run a 60-second system trace that logs diagnostic errors, warnings, and platform power capabilities. [1]
  • List Power Schemes: Type powercfg /list to view all available power plans and their unique GUID identifiers. [1, 2]
  • Change Active Power Plan: Type powercfg /setactive <GUID> to switch your active performance profile. [1, 2]
  • Check Wake Sources: Type powercfg /lastwake to see what device or event last woke your computer from sleep. [1]
  • View Sleep States: Type powercfg /a to display the available sleep states (like Modern Standby or S3) supported by your hardware. [1]
Video of basic power management and diagnostic commands using powercfg:
7m
1 Comment:
Yes, running powercfg was the 1st thing I did. I have tons of battery reports both with the original battery and with replacement batteries, including two iFixit BTI replacement batteries. The problem is upstream of this. The laptop cannot even run in BIOS under battery power before the SMBus handshake fails and the EC shuts it down, let alone Windows.
I have also cleared the EC a gazillion times (disconnecting the AC, disconnecting the battery, and holding the power button for at least 60 seconds). Things start running ok for a short time before all the problems re-emerge as soon as the SMBus handshake fails.
by
Add a comment
Add your answer
donfenix will be eternally grateful.
Past 24 Hours: 3
Past 7 Days: 22
Past 30 Days: 38
All Time: 38
