Up to 20% off select tools
The ZCT1 Controller varies by Generations, this is Gen 3 out of 6 AKA the JDM-020.
L3 doesn't work
L3 doesn't pressing don't work
Add a comment
1 Answer
Does the analog stick still make the click when you press it?
If it does, cleaning the joystick with contact cleaner may fix it.
If not the button is likely busted and the joystick module will need to be replaced. This does require a good amount of soldering skills and tools, but is doable at home with some patience!
DualShock 4 Left Analog Stick Replacement
Add a comment
Add your answer
hoda rifae will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 21
All Time: 85
