Up to 20% off select tools
The Acer One 10 S1003-114M is a convertable, allowing it to function as a tablet as wall as a laptop.
Display doesn't power on
On my Acer One 10 S1003-114M I have installed incorrect graphics drivers then the device when off, since then has never powered on again, but when I plug a charger cable I can see the charging light, please help on how to fix this issue. Thank you in advance.
1 Comment
no it's not the problem actually the main problem is it is not being power on even I ma clicking the power button
by Share
Add a comment
1 Answer
Chosen Solution
Your Acer One 10 likely entered a deep power-state glitch or suspended state (a "soft brick") due to the incorrect graphics driver. You can fix this by performing an internal battery reset to clear the system's memory and force a proper boot. Post your question in your browser and the AI will give you the details.
Score 1
1 Comment:
Thanks a lot I will do it you mentioned.
by Share
Add a comment
Add your answer
ZANDILE GRACE will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 47
All Time: 183
