The Chevrolet Corvette, known colloquially as the Vette, is a sports car manufactured by Chevrolet. The car has been produced through seven generations.
No brakes No pedal
What is the bleeding sequence after replacing the brake booster?
Add a comment
1 Answer
After replacing a brake booster, if you are going to bleed the brakes it is furthest from the master cylinder first. So if your master cylinder and brake booster on near the driver front (under the hood in front of the drive seat), you would bleed the rear right (rear passenger side) first, rear left next, front right next, and last the front left. Orientation is always determined from the perspective of sitting in the driver seat.
Add a comment
Add your answer
Arkie Bill will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 25
All Time: 25
