Released October 2023, Uses Rockchip RK3326 CPU.
it's stuck on loading screen
idk why everytime I open it it's just stuck on the loading screen, maybe bc the SD card is corrupt
Add a comment
1 Answer
Most Helpful Answer
Hi @minecraftjava
Try a power refresh and check if that resolves the problem.
Turn of the device (if it is on) and then remove the battery cover on the back of the device and remove and disconnect the battery from the motherboard.
Here's a video that shows what to do.
Press and hold the power button operated for a full 30 seconds and then release it.
Reconnect the battery and reinsert it into the device, replace the battery cover and check if it now turns on OK.
Score 1
Add a comment
Add your answer
Minecraft Java will be eternally grateful.
Past 24 Hours: 3
Past 7 Days: 37
Past 30 Days: 98
All Time: 309
