Up to 20% off select tools
Clean Water Tank Empty ... but it's NOT
We've had our Narwal Freo Z10 Ultra for about 6 months now. Love this thing! However, we seem to be having a recurring issue with the base station clean water tank. After filling the clean water tank and starting up, the narwal becomes angry from time to time and will say "fill clean water"... even though the tank is full and properly installed. My wife has found a temporary fix: using a baby medicine syringe to inject water into the base station clean water tank connection point. Doing this 3 or 4 times seems to clear up the issue... but a few days later same fault occurs. Anyone know of a root cause or complete fix?
Some things I have tried:
Cleaned both waste water and clean water tank thoroughly
Small pipe cleaner run through of all water lines to verify no obstructions
Thorough cleaning and maintenance of vacuum robot
This close to tearing the base station apart and doing a thorough cleaning.... when the wife isn't looking🫣
Add a comment
Did you end up ever taking the base station apart? I’m trying to take the rear panel off, but something is holding it in on the left side. Do you know how to take it off. As an answer to your question sounds like it could be a water pump issue.
2 Comments:
Attempted to pull base station apart, you have to remove the bottom panel to access the back. The plumbing inside is to tight to fully disassemble unfortunately. I will most likely review my warranty and contact supplier for support or replacement. The base station no longer registers a full clean water tank no matter what we do
by Share
Resolution! Success! Water pump issue indeed! Call tech support and luckily they are aware of the issue already. 1 year warranty covered repair and shipping cost. Base station returned with water pump repair!
by Share
Add a comment
Hello, I've had a Narwal Flow for a year now and we use it very heavily (every evening it vacuums and mops at least 50 m²). Twice I've had the problem of the base station not detecting the water tank, and both times I fixed it by manually forcing water into the base, which got the pump working again. To do this, I drilled a small hole in the cap of a plastic bottle, roughly the size of the clean water inlet on the base, so that when the full bottle is turned upside down and pressed lightly against the inlet, it forms a tight seal. After an initial refill from the bottle, squeezed to build up pressure, the base started reading the tank correctly again.
I should mention that when the problem first occurred, Narwal support was very responsive and suggested a number of fixes, but not this one, which I found on online forums instead.
Add a comment
Add your answer
Nicholas B will be eternally grateful.
Past 24 Hours: 4
Past 7 Days: 18
Past 30 Days: 114
All Time: 905
