The Xbox One S, designed by Microsoft Corporation, was released on August 2016. The Xbox One S is a redesign of the Xbox One.
Why Isn't My Xbox One S Working?
My Xbox One S Is Giving Me No Signal On My TV. But The Light Won't Turn On Unless I Press The Eject Button, It Will Run For Maybe 5 Or 10 Minutes Without Picture, Then Power Down. Neither The Power Or Sync Buttons Will Work.
Does Anyone Have Any Clue What's Wrong With It? I'm Thinking About Replacing The HDD Drive And Internet Power Source. Also I Don't Have A Brick Power Cable I've Got Just The Basic Plain Cable If That Helps Any.
3 Comments:
does it tell you no signal out when you turn it on?
by
Could be a lot of things. It will be easier if you upload a video. Is it possible for you to do this? Thanks!
by
Add a comment
1 Answer
No signal is usually a strong indicator of a bad HDMI port. While you wouldn’t expect this to affect the system to power on if the Xbox doesn’t detect an output signal it won’t power on. I would check this first. As it’s the cheapest fix but it does require some skill to replace. Other options would be a dead power supply bad capacitors can also cause this is a swappable part.
Add a comment
Add your answer
Chrystopher Lyle will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 8
All Time: 113
