Lenovo LOQ 15IAX9 with Intel i5-12450HX, up to RTX 4060 GPU, 15.6″ FHD 144 Hz display, up to 32 GB DDR5, PCIe Gen4 SSD, 60 Wh battery, and full I/O including HDMI 2.1 and USB-C.
My laptop doesn't power on
My laptop doesn't power on I've tried
Add a comment
1 Answer
@mwila just like any other laptop that does not start up, you will need to perform a few simple checks to get a better idea of where to start with any possible repair. Start off with the easy things. Disconnect the power from the computer by unplugging the power cord from your computer. Disconnect all external devices from the computer. Remove the battery Now hold the power button depressed for about 30sec-1min. Reapply the AC power adapter and see if your computer does show any sign of life.
First you want to check your power supply. Make sure it has the proper voltages. Check to make sure that connectors are not bend etc. Check the DC-in jack of your laptop. Make sure there is no corrosion, debris etc. that prevents it from working. Clean it of any debris etc., use a few puffs of air to clean it out. If none of this works, get an ammeter and see if your laptop draws any amperage from the charger. After that, you need to check and see if your motherboard even gets power. For that of course, you need to open it up. Post Some good pictures of what you see. That way we can see what you see.
To work on your computer use teh Lenovo LOQ 15IAX9 Hardware Maintenance Manual
Adding images to an existing question
Add a comment
Add your answer
Mwila will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 22
All Time: 184
