The Meta Quest 3S mixed reality headset was released on October 15th, 2024 and is a late smaller sibling to the Meta Quest 3.
Headset's tracking completely stopped working
I was playing VRChat on this headset and the tracking on it completely stops working where the cameras are off and the microphone only works if I hold the power button (after 5 seconds of holding it would shut it down) as well as the controllers not responding to anything beside the quest menu button so I had to use the head direction movements and volume buttons to navigate around the menus. I went to the Headset Tracking option and the switch is stuck on as it won't let me toggle it at all.I'vr also used ADB to clear the data of all the oculus system apps and restart it to safe mode but it didn't fix the problem. Is there something wrong with the hardware or does it need to be factory reset?
Score 1
Add a comment
It is possible for headset tracking to stop working due to sensor issues, software glitches, or connectivity issues. Ensure that the play area and lighting are properly set up, restart the device, and check the tracking cameras or sensors.
Add a comment
I would try to factory reset it but if that doesn't work try to send it back if you have warrenty
Add a comment
Add your answer
Kai Bannon will be eternally grateful.
Past 24 Hours: 5
Past 7 Days: 24
Past 30 Days: 72
All Time: 452
