Repair guides and support for the 24" iMac with M1 chip, introduced in April 2021. Identified by model A2438.
Display backlight malfunction, can I replace only the light?
The display back light malfunction from time to time, adjusting brightness all works fine, its just sometimes it goes dark, but if I look closely I can see the display content, Apple Genius Bar can only to change a new display to fix the problem, which cost like 50% of a new machine price, this is just a backlight issue, is it possible only to fix the backlight? thanks
Add a comment
1 Answer
This series has had a few backlight issues with vertical banding. This is due to a display panel defect and how the systems cooling design fails to keep the display cool.
The display panel is a fused unitized part in this series as such you can't really replace the backlight without damaging the display. Here's the guide we have to take it off iMac M1 24" Display Replacement
Add a comment
Add your answer
Jack will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 8
All Time: 46
