Repair and support for the controllers that shipped with the PS3. Released in November 2007 (Japan only) and 2008 (other countries), the six-axis lithium battery powered controller (CECHZC2) is straightforward to repair.
What's wrong with player indicators LED on the ps3 controller?
Hi, so I have a ps3 controller that doesn't indicate what player you are the red LED doesn't light up on the controller
5 Comments
Hi!
Does it light up when you are trying to charge it?? Do you use it with your PC or PS3?
Thanks!
by
I mainly use the controller for ps3 and they dont light up when I charge the controller, but the controller works
by
If the light doesn't show when it is charging, your LED is probably burnt out. Are you familar with basic soldering? If so, it should be pretty easy to remove the case and PCB and solder on a new LED
by
Yes, I'm familiar with basic soldering
by
Then I would replace the LED's and test to see if that works! But before doing this, please try to clean the board with isopropyl alcohol.
Thanks!
by
Add a comment
1 Answer
Chosen Solution
Hi!
Just as teardown-er mentioned, it's probably the LED's it self, or there is corrosion somewhere that can cause this.
Please disassemble the controller and clean the whole motherboard with isopropyl alcohol (also the LED's) and check what is happening after this.
Otherwise, you could replace the LED's and see if that works.
If the issue persist, then it's most likely something on the motherboard that did die.
Can you let us know how cleaning worked?
Thank you!
Score 2
5 Comments:
Hi!
You need the following LED's: 4 x 0603 or 0805 SMD LEDs
You can find more info here: https://www.instructables.com/Playstatio...
You can buy them at Amazon, eBay or even AliExpress.
by
Awesome thanks I need to the controller apart anyway since its drifting
by
My pleasure! Hopefully you will get it all fixed! Please let us know how it goes :)!
by
Hi, when I took the controller apart I noticed that two of LEDS where missing from the main board
by
Okay, in this case you need to solder new ones in. Do you have any soldering experience?
by
Add a comment
Add your answer
Christopher D will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 36
All Time: 209
