Repair, disassembly, and troubleshooting information for the JBL Flip 6, a portable Bluetooth speaker, released in September 2021. It is equipped with a woofer and a separate tweeter, dual JBL bass radiators, and features IP67 water resistance and a 12 hour battery life.
Can't enter AUX mode
I've watched several videos and followed online guides trying to access AUX/service mode but when I press and hold the bluetooth and play/pause buttons it doesn't shut down as it should. I have tried with numerous cables and no luck. Is there something wrong with my device or am I doing something wrong?
I am also unable to execute any command involving holding multiple buttons down. I have attempted a factory reset to no avail. It is unclear whether or not I need to contact JBL and have it looked at by a professional.
Add a comment
1 Answer
Peace be upon you.
At first use oil. then
The JBL Flip 6 lacks a traditional 3.5mm AUX input but supports a USB-C "AUX mode" (also called service mode) for wired audio playback from a connected device. Your issue with buttons not responding to multi-press combinations, including factory reset attempts, suggests the speaker may already be stuck in service/lock mode, where buttons are intentionally unresponsive.​​
Correct AUX Mode Steps
Ensure the speaker is powered on first. Press and hold the Bluetooth (rear) and Play/Pause (front) buttons simultaneously for 10-20 seconds until it shuts down and restarts—then connect a USB-C to USB-C or USB-C to Lightning cable from your source device (phone/laptop) for audio. Buttons like volume won't function in this mode; control from the source device.​​
Troubleshooting Button Issues
If multi-button presses fail entirely, the speaker is likely locked: Plug in the USB-C charger (required), then press and hold Bluetooth + Play/Pause for 10-20 seconds to exit service mode. For factory reset afterward, hold Play/Pause + Volume Up (+) for 5-10 seconds until it powers off. Persistent unresponsiveness may indicate hardware faults like button damage, common in repairs or fakes—test single buttons first and consider JBL support if unresolved.​​
When to Contact JBL
Contact JBL support or a service center if resets fail after charging, as this points to potential flex cable/button defects rather than user error. The device, released in 2021, has a typical 1-year warranty, but check your purchase date.​​
Add a comment
Add your answer
devans3543@gmail.com will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 14
Past 30 Days: 143
All Time: 649
