HP Officejet Pro 8620 is a multifunction printer for copy, scan and duplex. This device can be identified by its model number: SNPRC-1401-02
Why won't my 8620 HP printer print?
I replaced the large black cartridge with a small one and it hasn't worked since. HELP!!
1 Comment:
Is the new cartridge original or compatible? Have you tried with another one?
by
Add a comment
1 Answer
You need to replace the cartridge with the original large cartridge. Putting the incorrect cartridge in will cause the printer to malfunction.
I spent many hours trying to get away with alternative cartridges, both size and brand. But in the end, with printers, you have to go with the exact replacement and buy the same brand cartridge that the printer is.
If you do this, it will save you a lot of time, frustration, and money.
Also most box stores should have a place to recycle old printer cartridges that you no longer have a use for.
Add a comment
Add your answer
Kenneth Fowler will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 12
All Time: 71
