Can't charge the battery
tidak bisa mengisi daya batre mentok di logo pengisian batre
Translation Indonesian - English
Can't charge the battery, stuck at the battery charging logo
@driveerthon first make sure that the selected device is the phone that you have. This was auto selected since you've left this question as an answer to another question.
Next it will help if you can tell us what you have already checked and what you have tried.
First check your charger. Make sure it has proper output. Then check your charging cable. Check to make sure connectors are not bend etc. After that, check the charging port. Clean it of any debris etc, use a few puffs of air to clean it out. If none of this works, get a USB ammeter and see if your phone draws any amperage from the charger. If it does not it is possible that this is a charging port issue or a bad battery.
To check the charging port, use a voltmeter and measure the voltage on your battery connector. Next plug your phone charger in. Now measure the voltage on your battery connector. That voltage will have to have increased. If not then the issue is either the port or the charging circuit.
Personally I would change the battery and while the phone is already opened, I'd replace the charging board as well. Since iFixit does not yet have a specific guide for thi, use something like this video Re-evaluate your charging after you do this.
While you work on your phone, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has a device with the same issues as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Repair is War on Entropy!
Translation
@driveerthon, pertama-tama pastikan perangkat yang dipilih adalah ponsel Anda. Ini dipilih otomatis karena Anda meninggalkan pertanyaan ini sebagai jawaban untuk pertanyaan lain.
Selanjutnya, akan membantu jika Anda dapat memberi tahu kami apa yang telah Anda periksa dan apa yang telah Anda coba.
Pertama, periksa pengisi daya Anda. Pastikan output-nya sesuai. Kemudian, periksa kabel pengisi daya Anda. Pastikan konektor tidak bengkok, dll. Setelah itu, periksa port pengisian daya. Bersihkan dari kotoran, dll., gunakan beberapa semprotan udara untuk membersihkannya. Jika tidak ada yang berhasil, gunakan amperemeter USB dan periksa apakah ponsel Anda menarik arus listrik dari pengisi daya. Jika tidak, kemungkinan masalahnya ada pada port pengisian daya atau baterai yang rusak.
Untuk memeriksa port pengisian daya, gunakan voltmeter dan ukur tegangan pada konektor baterai Anda. Selanjutnya, colokkan pengisi daya ponsel Anda. Sekarang ukur tegangan pada konektor baterai Anda. Tegangan tersebut pasti sudah meningkat. Jika tidak, maka masalahnya ada pada port atau sirkuit pengisian daya.
Secara pribadi, saya akan mengganti baterainya, dan selagi ponsel sudah dibuka, saya juga akan mengganti papan pengisi dayanya. Karena iFixit belum memiliki panduan khusus untuk hal ini, gunakan panduan seperti video ini Evaluasi kembali pengisian daya Anda setelah melakukan ini.
Saat Anda sedang menggunakan ponsel, ambillah banyak foto. Setelah selesai, ambil foto-foto tersebut dan buatlah panduan untuk iFixit. Itu akan membantu orang lain yang memiliki perangkat dengan masalah yang sama seperti Anda. Membuat panduan ini mudah dan menyenangkan. https://ifixit.com/Guide/new Komunitas iFixit akan menghargai panduan ini.
Perbaikan adalah Perang Melawan Entropi!
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 37
All Time: 411
