The first FWD car to be exported to North America by Volvo
My hood don't open
Hello, how are you? My car's hood won't open! When I pull the internal lever, only one side of the hood locks releases, while the other remains stuck. Could someone help me?
Add a comment
1 Answer
Most Helpful Answer
@davifarias try and have a second person push down on the side where the hood does not open. That may free the stuck hood. You could also try and use a pair of vise grip pliers to pull the cable a little harder and further then the actual hood release does while someone pushes down on the hood. Once you do have it open, check the "bumper" for the hood. You may need to adjust it so your hood is being "pushed" up further then it does now, when you close it.
You could also see if something like this as well as the write up by user "boxpin" on here will work for you.
Score 2
Add a comment
Add your answer
Davi Farias will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 11
All Time: 185
