Up to 20% off select tools
Ultra-Thin Laptop Processor: Intel Celeron N4120 @1.1GHz 1101MHz Turbo Boost: @2.6GHz GPU: Intel UHD Graphics 600 8GB RAM DDR4 256GB SSD TPM 2.0 (Supports Windows 11) Has fingerprint reader. No optical drive. 720p HD camera. Kensington Lock 2x USB Type-A 3.2 Gen 1 (5 Gbps) 1x USB Type-C Bluetooth 5.1 3.5mm Combo Jack Full HD IPS panel 1080p 60hz display Comes preinstalled with EFI Shell. (Windows is easy to install)
Screen doesn't turn on
My screen started flickering and just went black I've tried everything still hasn't turned back on
Add a comment
1 Answer
Most Helpful Answer
Does the computer appear to be on other than the black screen? If so, there are two things to try next.
  1. Shine a flashlight on the screen in a dark room. If the backlight has gone out, you'll still be able to make out an image on the screen; try different angles for viewing and the light.
  2. Try plugging in an external monitor; if you have a USB-C to HDMI adapter you can plug it into a television. Anyway, if the external monitor works then your LCD may have failed and would need to be replaced. Note that there may be key sequences you have to press to enable the external monitor; that should be documented in your users manual.
Give those things a try then come on back and let us know what you find.
Score 2
Add a comment
Add your answer
Light will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 18
All Time: 262
