Repair and disassembly information for Sony WH-1000XM3 wireless noise-cancelling over-ear headphones.
Headset won't charge or turn on
I dropped my headphones and broke the headband on the right earcup. Was able to to reassemble the head band and the headset worked for a while but now it won't turn on or charge anymore. The wire in the headset is kinked but I'm not sure if that's the cause
Score 1
2 Comments:
That is quite normal for those wired to be kinked a little. I believe it could be that your battery connection got dislodged or other components of the motherboard in the cups broke off. Do you have a photo of the disassembled earcups?
by
It was actually some wires touching in the left ear cup. Found a a guide that fixed it
by
Add a comment
1 Answer
Found this guide on here and and it was actually the solution to my problem
SONY WH-1000XM3 Teardown
Add a comment
Add your answer
Grant Vrban Brown will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 38
All Time: 383
