Up to 20% off select tools
The Asus A541U line is part of the Vivobook Max series by Asus. These include the models; A541UA, A541UAK, A541UJ, and A541UV released in various years.
Power Button doesn't work
The button doesn't respond at all
1 Comment:
@siphumelel69527 have you checked for power on your laptop? Any LCD's lighting up or blinking when you connect your power adapter?
by Share
Add a comment
1 Answer
Well try the following it some the basic way to fix this issue:
  • Check charger & power outlet: Ensure the laptop is plugged in and the outlet works.
  • Battery indicator: If any lights turn on when plugged in, the laptop may still be functional.
  • Unplug the charger and Remove the battery (if removable) And then Press and hold the power button for 30 seconds.
  • Reconnect the battery and charger, and try turning it on.
Add a comment
Add your answer
Siphumelele NDLOVU will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 17
All Time: 314
